Thanks to all, I have learned a lot from reading the threads posted on this site.
This is my first attempt to post a thread, so I will try to state the problem clearly.
I am trying to learn as much as I can at home, and be as thrifty as possible. I have the LogixPro CD, and Phil's Book. I have done many of the learning exercises that come with LogixPro, so I am familiar with the basics of ladder logic.
The problem I have with simulators is they do not teach you how to connect and communicate with a real processor. In an attempt to learn this vital skill, I downloaded from Rockwell the free Rslogix 500 Starter For 10 Pt Micrologix 1000 and Rslinx Lite.
I also purchased a Micrologix 1000 Model # 1761-L10BWB Series E
and a 1761-CBL-PM02 Cable, both were bought on Ebay.
When powered up the Micrologix Power and Run leds come on and some of the outputs change state. I believe this indicates that there is a program running in the processor.
When I connect the cable, and start Rslinx, and do the superwho function in Rslinx it shows the processor as active. When I do the diagnostics on the processor it shows communication status active, and packets being sent and received.
When I try to go online with Rslogix it gives an error "No response from processor at selected path/node!" "cannot connect to remote emulator".
Attached is a Word .doc file with screen shots that may help.
I have searched the Rockwell knowledge base, and the help files in Rslinx and Rslogix, but have found no help with this issue.
Thanks in advance.
Barry
Thanks in advance.
Barry
