Trouble going online with ML 1200
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day. I'm trying to go online with a Micro Logix 1200, using RSLogix 500. I tried configuring the driver using 1784-KT/KTX........for DH+/DH-485 devices and as soon as I do, I get the "blue screen of death" every time. I then tried the 1747-PIC/AIC+Driver and it gives me a "DiagnosticStatus failed: 0xFFFFFFE" pop-up. Any help would be greatly appreciated.
Definitely don't use the KT driver... that's for ISA and PCMCIA cards.
Use the ordinary "RS-232 DF1 devices" driver, use an ordinary 1761-CBL-PM02 serial cable, and press and hold the "DCOMM" button on the controller until the DCOMM LED turns solid green.
This will get you connected using DF1 Point-to-Point protocol, at 19200 baud, with CRC error checking. If you have a built-in serial port, the Autoconfigure feature will work. If you are using a USB or expansion serial port, Autoconfigure might not work (just use 19200 baud, SLC/Micro controller type, CRC error checking) and you need to confirm using the Windows Control Panel which Windows logical COMx port your physical port is using.
Hello all. I have an acd that was created in RSLogix 5000 v.21 with Windows 7 OS. I don't have a laptop with Windows 7 nor do I have a VM with it...
1,416
HELLO ALL. I've done this once before and had no problem. We have just recently had a new piece of equipment with a ML1400 and a PV Plus 600...
2,578
Thanks to all, I have learned a lot from reading the threads posted on this site. This is my first attempt to post a thread, so I will try to...
8,827
After the new very nice update to this site I could not log in with my original password, tried to recover my account but did not recieve a email...
404
Hi everyone. I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I...
539
