Troubleshoot Balluff I/O Block (BNI00E1)
Jun 2023
Ohio
Hello,
I have a balluff network i/o block, BNI EIP-538-005-z063, and I can't establish a connection with it from my PC or PLC. I tried pinging it as well and lost every ping. All of it's setting are still factory set. I have all green lights on US, UA, MOD, NET(FLASHING). The LK1 light flashes green, but never holds green. I'm using all brand new cables on it as well. I need any advice or guidance on what I need to do to be able to communicate.
Try connecting it directly to your PC running Wireshark, start the Wireshark on the LAN connected to the Balluf device, then power off, and power on the device. It should report its IP address in the ARP broadcast.
preconfigured, I realized that because of subnet mask 255.255.255.0, I had to match the first three bits of my ip address to match it's for a connection. It was on 192.168.1 and I was on 192.168.0, apprepciate the help
Does anyone know of a good person/company that could troubleshoot an electrical problem in a control panel in South Carolina - tomorrow? If...
2,223
My attempt to communicate with Foundation Fieldbus transmitters with Pactware and a new, out-of-the-box Softing FF modem are a disaster - failure...
17
5,089
Hi, I am dealing with a single SBR subroutine thats handed 1 input paramter UDT P.x multiple times: (Pump) P.1/2/3/4/5. I JSR into the same...
2,005
Hi all, I've been making good progress with the WWTP lightning strike issue, CPU and I/O for the Plant PLC is up and running, and data is coming...
1,807
I have a customer in Phoenix AZ that needs a service call for help with a Telemecanique TSX17 plc system. Can anybody help?
1,426
