Hello everyone. First post here; hope it's not a dumb one.
The plant where I worked shut down three years ago. I was out of work for two years and went back to school to get an electronics degree at a local community college. I learned some basics about PLCs there; enjoyed it and did very well. Now I'm working for a very small company and one of our systems is having issues. The PLC is an AB Micrologix 1200. Their is no documentation about the programming. We just bought an RSLogix Micro program and cable that I was told will work with it, though I haven't tried it yet.
There are two 20hp fan motors, primary and backup, and their corresponding dampers controlled by the PLC, as well as a couple pumps. There are several things that can make the fan trip over to the secondary side, and I have mapped out all the inputs and outputs to understand what happens.
It has worked fine until several days ago when there was a momentary power failure due to weather. Now it seems stuck on the secondary. When I have the fan selector set on Hand it will stay on fan 1, but both fan 1 and 2 dampers are open (not right- these should never be open at the same time). When I switch to Auto it instantly switches to fan 2. Fan dampers also stay open even when selector is set to Off (also not right- I have never seen it do this in the past).
Of course I don't expect anyone to understand the system without seeing it, but it sure seems like a PLC issue. I have listed and understood all the inputs and outputs (took me a while without documentation), and all inputs are normal. I have played with it quite a bit, watching input and output indicators as it switched, and can't see anything coming in telling it to misbehave.
I talked to the salesman that sold me the RSLogix program, and he said it sounded like a stuck bit (?) due to the power failure. We cycled the power a couple times with no change. I haven't had the chance to hook up the computer to it and see what the program is doing, waiting for the right window and this system can't be down very long. I'm also a little concerned that I might do something wrong and screw it up worse. Top grades in a couple classes don't translate into very much know-how, and I am vaguely aware of just how much I don't know.
Any tips or ideas would be greatly appreciated. I hope I'm not being presumptuous with such a long-winded question on my first post. Thank you for any and all responses.
