try to delelope communication between profibus dp and modbus
kraj
Feb 2010
p
82
hello
is there is some solution on it
i have siemense plc on one side and n/w used is profibus
which is a master one
and on other side there is modicon plc which is slave n/w used is modbus
i am trying to fecth data from slave to master
how can it possible
thanking you
raj
THANKS mjoubert
u mean human interfACE M/C
CAN U SUGGEST ANY GATEWAY OR INTERFACE CARD DIRECTLY
hello
how can it possible
thanking you
raj
Hello raj;
If your Siemens PLC is of the S7-300 family, you could setup a CP 341 (serial comm processor) as a Modbus master and request data from your Modicon Slave.
If it is a S7-400, then you could use the CP 441-2 for the same purpose.
Here you can download the manual for the Modbus Master driver manual:
http://support.automation.siemens.com/WW/view/en/1220184
This FAQ mentions all drivers that can be loaded in the CP 341/CP 441-2, so you can select the correct part number:
http://support.automation.siemens.com/WW/view/en/1918186
With this information you can decide if the Siemens driver is a solution for you.
Hope this helps,
Daniel Chartier
hello
hi dchartier
thanks for ur reply
my plc s7 -400 but it is on profibus n/w which act as a master
and modicon plc on modbus n/w which act as a slave
so i need something
which convert protocol both ways
thanking you
raj
Hello raj;
Hope this helps,
Daniel Chartier
hello
one more thing
modbus n/w is on tcp/ip
not on rtu
so suggest some protocol converter
i.e profibus dp to modbus tcp/ip
or vice versa
Hi there
Will the modbus communication take over ethernet? If so then you just need a ethernet cable running between two CPU's. If not then you need CP441 as mentioned by dchartier.
Cant make it from your statements what you have !
courtesy:
which is a master one and on other side there is modicon plc which is slave n/w used is modbus
and
one more thing
not on RTU??
confusing....can you go clear?
thanks
thanks ,manmeet
ther eno confusion
as there two modes of modbus
one rtu
and another is tcp/ip
among them we use modbus tcp/ip
actually we had a gateways which siupport modbust rtu
so the tht i mention it.
tht we need solution on profibus dp to modbus tcp/ip
protocol converter
Hi there
courtesy:
and
not on RTU??
Hi everybody, I have about three Red Lion HMI's, the calibration on the screens seems correct but where I'm using the pop up keypad to enter...
119
Hello, So i managed to read the string coming from control logix and put a string display in PanelView 800. Now I am struggling to do the other...
152
I'm running into a problem when trying to use the RSLinx Backup Restore Utility where it throws an error when it tries to restore a backup. The...
593
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
273
Hi all, This is my 2nd post and I just want to say thanks for your feedback! I appreciate every single one of your responses! I have been...
17
1,784
