Trying to download to a PVPlus 6 - not visible
phuz
Jun 2008
Mohnton, PA
1,044
I've never had this issue, so I'm wondering if the Ethernet is just bad on the Panelview, but neither RSLinx nor Enterprise will see the PanelView plus, however I can ping it fine. I am connected directly, and have tried with/without the crossover adapter. It just won't see it, and therefore cannot download to it.
2711P-T6C20D
Try turning off WiFi, if you have more than one adapter running.
Do an ARP -A in a command window to be sure that the thing you're pinging is really the MAC address of the PV+ (available in the configuration menus).
Try the "Ethernet Devices" driver in RSLinx Classic, where you enter the IP address itself. While it's functionally irrelevant because PV+ download uses RSLinx Enterprise, it can help you diagnose what's going on.
And try resetting the PV+ comms drivers to default, using the configuration menus. If the Ethernet driver in the onboard RSLinx Enterprise gets deleted or screwed up, the terminal won't show on any browses.
And last, you can always make a *.MER and load it onto the terminal via the CF/SD/USB ports.
Hello! When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer. When checking the buffer, it says...
204
Hi, New to the forum. I have an old machine I am working on that is using aA172SHCPUN. I want to capture the program in case I need to reload...
22
2,093
Hi guys! I'm trying to download a project to the controller, who already has an aplication running protected by a blank password. The option to...
2,928
Good Morning , I received a used 1756-L62 / A CPU , from a vendor that was using it for a trainer. I tried to download a program that is...
1,486
We're a used machinery merchant and have a Siemens PLC that has lost its program due to a dead battery. We have the software to download but, at...
22
6,647
