TSX micro and GSM modem
ioannis
Mar 2003
I want to connect a TSX Micro PLC of Modicon – Telemecanique (TSX3722) to a GSM Modem, in order to send and receive SMS messages.
For these I use a PCMCIA Type III communication card TSX SCP 111, which is connected, through a cable RS232, to a GSM modem (TC35 of SIEMENS). The PCMCIA supports 3 protocols: Character mode, UNI-TELWAY and Modbus and the GSM modem can be controlled and programmed by means of AT commands.
The only function of the software PL7PRO that supports the AT commands is the CALL_MODEM, which can be used only with the TSXMDM 10 card (card for communication with switched telephone network) and not with the TSX SCP 111 card.
Does anyone know what can I do in order to solve my problem?
TSX and GSM
Hi
I think the TSX Micro is a re-branded IDEC Micro 3 PLC, which itself has been superceeded by the MicroSmart. The MicroSmart can be set up to send SMS messages, with embeded variables, via a GSM Modem - look at www.sendtech.co.uk and www.cyberneticbe.com for more details.
Mark
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
146
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
372
I'm working on a Schneider TSX Micro TSX3722001 with an alternately flashing ERR and TER led. The machine has been idle for about 3 years and I...
995
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,541
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,640
