TSX Micro Internal Addresses
Dec 2005
Rio de Janeiro
Hi, friendly people !
I´m a guy from Brazil, really not so expert as many of you I have seen here.
I´m indirectly involved in the integration of a TSX Micro PLC from Modicon (Schneider) with a IFix (from Emerson) application.
I have been asked for the internal addresses of the TSX Micro cpu, to deliver to others of the team. I got the infomation below in this site, but it seems no so complete as we need.
0xxxx discrete outputs and internal coils
1xxxx discrete inputs
3xxxx analog inputs
4xxxx analog registers
For example, if I have an digital input like %I0.0, a digital output like %Q4.4, a analogic input like IW6.1, a internal floating like %MF4, how can I address them ?
I thank you for all help you can give me.
Wishing a nice year of 2005,
Roberto Camargo
You are correct the TSX Micro addressing like your example.
The IFix probably uses a Modbus format where 4xxxx is a word and 0xxxx is a coil. IFix knows how to handle double words and floating point when doing Modbus communications.
I am not certain, but I believe that the only TSX Micro conversion for Modbus communications would be:
4xxxx = %MWx-1, for example 40001=%MW0, 40002=%MW1, 40003=%MW2
0xxxx = %Mx-1, for example 00001=%M0, 00002=%M1, 00003=%M2
Thanks, Jim.....
For the first time I was preparing this problem to be presented, I made it complete. But then - Murphy is alive ! - my pc was reseted and I lost some parts of the problem.
If I was using a normal comunication, I believe I would not have this problem. The question has arised because we have a Digi One SP Ethernet to RS 485 converter between the two communicating elements..... I can say I know almost nothing about the Modicon line, but I think this is not the way Modbus works (may be I´m wrong....).
You gave me the answer thinking about the internal coil and the internal register. But I still could´nt apply this rules over the examples I presented, that are the situations I have to resolve.
Lots of thanks and my best regards,
Roberto Vieira de Camargo
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
137
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
367
I'm working on a Schneider TSX Micro TSX3722001 with an alternately flashing ERR and TER led. The machine has been idle for about 3 years and I...
990
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,538
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,637
