tt4000 showing vale ????
nEWBIES
Jun 2015
sabah
I am a newbie here, I would like to ask for any advice regarding the problem I facing, I have opened up TT4000 designer and start a project, the thing is once I was inside the RUN MODE, all the value only shown "???????" instead of decimal value, for your info I just done replacing the HMI, is there any configuration that I might miss out?
Thanks.
Hello and welcome to the forum.
Never used TT4000 (or heard of it for that matter) but it sounds like since you say you just replaced the HMI, you are missing your comms or project file for/to the PLC.
(shooting in the dark here)
Here is another thread I found on this site.
See if it points you in the right direction.
http://www.plctalk.net/qanda/showthread.php?t=53035
Good luck
BCS
Solved, it was really like your saying, it was the communication problem, to be specific it was a communication driver problem, just set up a new communication driver, restart the pc and there you go,btw thanks for the advice bering.Cheers.
Hi, as part of a project to bring an old retired power plant back on-line we need to access a single existing TT4000 HMI used to interface 2 Solar...
466
Hello fine people, hope you are well. We are doing some data analysis from this compressors from Solar, but my company its taking a lot of time...
2,266
Has anyone out there dealt with Solar's TT4000 software? I've got a strange issue here. We have 5 compressors all online with their own individual...
4,627
Hi Friends; We have gas turbine from solar turbines Inc. The control system is rslogix 5000 version 15 and HMI design in Turbotronic 4000. Is it...
7,463
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
107
