Twido connection RS232
userxyz
May 2002
any
2,768
I have a TWIDO TWDLCAA16DRF PLC that blinks its RUN led but doesn't startup. I have TwidoSuite 2.2 installed and I received a cable from a collegue with a TSXCUSB232 converter. For connection between USB/PC and the TWIDO, schneider advices to use a TSXCUSB485D converter.
However I have found that the TSXCUSB232 should work as well.
A Twido has both electrical interfaces, RS485 and RS232.
So the RS232 converter should work.
Weird part about the cable I got is that is does not fit the PLC connection:
It has some kind of black pin...
It should be a cable like this:
This is the PLC side:
I could build an own cable... or should I be better of by buying the cables
TSXCUSB485D+TSXCRJMD25 ...
What do you guys think ?
Anyone had troubles with this communication as well ?
Thanks,
Kind regards,
G
HI TO ALL, i have a unconfigured TWIDO TWDLCDE40DRF..i cannot connect to the pc..what should I assigned IP to my PC?.. is it similar to the...
1,572
Hi All, I have already Posted regarding Twido But no one replied. Please Tell my Twido Mac address is 0080F4832372 & by the conversion of Last 2...
1,945
Hello, I have a Schneider PLC Twido TWDLCDA24DRF, and I need to change some parametres. I have RS-485 converter and made connection cable by...
3,356
Hello everybody! I am having an issue I'm hoping someone here can help me with. I have a TWDLCAA24DRF plc which I have configured to act as a...
5,411
I have 4 twido connected to ethernet. TWDLCAE40DRF TW1 no expansions TW2 7 expansions TWDAMI8HT, 8 x 4-20mA inputs TW3 7 expansions TWDAVO2HT, 2...
3,827
