Twido with Ethernet port problem
Aug 2009
cairo
Hello all,
I will try to describe my problem as clear as i can, I hope you will forgive my bad English. I have One TWIDO TWDLCAE40DRF and there are 3 Slaves with the same type of master. I tried to make a network using an Ethernet switch (D-LINK) switch. I wrote the code and tried to use a timer to handle the communication between the 3 slaves but once i tried to disconnect one of the Slaves all other Slaves and Master PLC will go down too. And when i reconnect it again it work fine. I don't know what is the problem exactly. I tried to change the time out of the Remote devices but no way still i have the same problem.Wish someone can help me to solve this problem.
Thanks colleagues,I did solve my problem myself. But i really hoped that one can answer or even share ideas with me. If anyone care about the answer just ask.
I think all my problem was about the Connection Timeout it was based to 100 ms and i writing another 100 ms in the table of remote devices.So the solution is to reduce the types timeout to 1 then it will be multiplied by 100 ms. In my first program i did type 100 ms in the table so 100*100= 10,000 ms .It's such great period to establish another connection. Using also %sw65 is good choice if you want to check your connection and network.I hope even after replying for my own problem i could help anyone.
Does anyone have any experience using the Twido PLC TWDLCAA24DRF with the TwidoPort 499TWD01100 Ethernet adaptor. We have recently installed 6...
8,407
Hi All, I have already Posted regarding Twido But no one replied. Please Tell my Twido Mac address is 0080F4832372 & by the conversion of Last 2...
1,945
I have a twido TWDLCAE40DRF PLC, IP 192.168.0.1, connect to a network switch port 1. Also, I have a modbus Power Meter (Device ID: 5, PLC try to...
8,955
I have 4 twido connected to ethernet. TWDLCAE40DRF TW1 no expansions TW2 7 expansions TWDAMI8HT, 8 x 4-20mA inputs TW3 7 expansions TWDAVO2HT, 2...
3,828
Hi everyone, i'm new here at plc talk, so i hope someone can help me with my little problem. I have a problem to connect my pc to 2 separate...
5,440
