Two 20-750-ENC-1 in one PF755
asdf6
Apr 2018
Vancouver, BC
Is it possible to use two single encoder cards (20-750-ENC-1) in one VFD (PF755) as apposed to using a dual encoder card (20-750-DENC-1)?
Trying to work with what is currently available as i am currently doing commissioning.
Good Morning , I am replacing a Allen Bradley 1336 Impact drive with a PowerFlex 755. The 1336 had a 1336-L6E /L9E w/ Encoder board in it ...
1,892
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
130
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
383
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
352
