types of plc
You may want to clarify your question. Are you asking how many name brands or how many different styles of PLC's??????
I am fairly certain this was a poorly phrased question on "styles" of plc...ie the old brick, modular, rack question. I was being a smart A with my original answer but since English isnt the posters original language there may be some translation issues.
There are 3 "styles" of plc as I mentioned above. The brick, now commonly called "micro", modular and rack. The "modular" style is becoming defacto for high end applications. The micro is becoming more expandable making it more "modular". This link will offer more info on "styles" etc but is becoming outdated.
http://www.freestudy.co.uk/plc/outcome1.pdf
To clarify more a plc is what the name implies...a controller. It can use different types of inputs and outputs...discrete(digital), analog, high speed etc. It can use many different communication standards and protocols.
Please use more detail when asking a question, if you have a problem with English there are many here that may translate or assist in your native language.
Brick or micro example: http://www.ab.com/micrologix
Modular: http://www.ab.com/plclogic/slc/index.html
Rack: http://www.ab.com/plclogic/plc5/
Their are several different types of plc`s.
square d modicon,ge fanuc,klockner moller,omron,allen bradly very
easy to use.
There are actually three styles, but because we don't look like everyone else, we are often forgotten.
1. Brick
2. Modular / Rack Mount
3. Embedded / Board Level
A question to those of you who separate Rack Mount and Modular...how is one different from the other.
As Ron had mentioned, there are now some brick that have slots for additional expansion, but they are still bricks, only with expansion slots.
Beats the heck out of me, but those three seem to be the answer to question 1 on the archaic industrial control class homework :)
The SLC 500 family is a growing family of small programmable controllers built around two hardware options: a fixed controller or a modular controller.
Thats ABs own words from the first link.
Modular the PS and/or CPU may be part of the mounting system.
Using the PLC5 as an example of rack mount PS, CPU etc etc are separate items.
These days there is a fine line on the fifferential
I agree, that there are three kinds.
But what are the three???
Big, little, and in between, or
Pretty, ugly, and pretty ugly.
Just my perception, with no real formal training.
m
b
f
I wanted to buy siemens 6ES7212-1AE40-0XB0 s7-1200 plc but i wanted to know if i can communicate with my plc with an ethernet cable or not. And...
2,965
I have a function block (FB1) which uses internal tags and has made a data block (DB1). I have a created a PLC data type with around 15 tags and...
1,704
Hi, do you know what types of plc can read a data barcode (ascii) and/or send data ascii to another item? i know that plc click of...
3,486
dear everybody again I Have a question for your, please. can you help me I have a machine it's use plc mitsubishi to control for machine runing...
24
8,670
So i have chosen a traffic light. 3 plc units are unitary modular and rack mounted. i need to identify and describe the 3 type of programme...
19
13,143
