Ultra3000 E09 Bus Undervoltage
derrickjp7
Apr 2019
Minneapolis, MN
Anyone know what might cause this?
All my other drives are working fine except this one. Sometimes I can start the drive, it'll run fur 5 seconds then error out. Most the time I'll run a MSO in the Direct Commands and it errors out immediately. All the wiring is fine and I've held a volt meter to the AC and DC inputs to the drive while initiating MSO instructions and there's no drop or interruption to power. Is there some parameter I may have unintentionally changed?
Any help would be greatly appreciated! Of course this has to happen the day before my final capstone presentation. Murphy needs to leave, now. Haha
Do you have access to a spare drive? This could be due to a number of internal reasons, but the simplest way to rule out a bad drive would be to swap it out temporarily. If that's not the problem, I've seen intermittent issues due to an overloaded infeed; when other drives would pull an excessive amount of current, another would fault out. It wasn't obvious as this would be a very short "outage".
Good afternoon all, We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has...
437
Hello, I have an issue with one Ultra3000 servo drive. I command an 1326AB-B520E-S2L motor and after 30 min the drive goes to fault with the E22...
1,649
Ok so first allow me to bow my head and say I'm a retired mechanical engineer and while I still have a few brain cells left there is something I...
3,958
Hey all, For a school project I've been tasked with getting a ControlLogix, Ultra3000 and some servos that were donated up and running...
1,569
Dear Sirs, I have a machine with four Ultra 3000 drives in it. The Ultraware software is installed on a computer as part of the machine. We...
2,508
