Ultrasonic level sensor
MiPilot
Nov 2009
Michigan
27
Hi guys
I am looking for an ultrasonic level sensor that will measure up to 135 feet.
I have a customer with several grain bins that are 135 feet tall and would like to monitor the grain levels without having to send someone to the top and look inside.
If this is possible, and how well do these handle dusty conditions and yet remain accurate?
Thanks, Steve
I agree. Ultrasonic is not the correct sensor type for this application. There will be too much beam spread at 135 feet for it to ever work reliably unless this is one huge silo.
Siemens (former Milltronics) ultrasonic XPS-40 transducer can shoot 130', but for dusty conditions, the Siemens LR400 4 wire radar is dynamite. It shoots through dust in grain silos here in the midwest all the time. It's rated to 164 ft.
I installed seven Sultan Ultrasonic sensors from Hawk Measuring Systems last year in tanks measuring 12' to 25' tall and from 6' to 10' in diameter and have been very happy with their performance, technology and support. They have built-in algorithms that compensate for dust and the units were originally designed for dusty environments. Here is the website for the product that I have used. The price was great, too, and by paying for them to perform the setup and initialization, I received an extended warranty.
http://www.hawk.com.au/productdetail.asp?id=1
Regards,
I haven't used a Vega, but the Siemens LR460 goes for about $2,700 US depending on the antenna.
Hey, you gotta shoot over 100' . . . .
Yes, that price for the Ohmart-Vega is correct... as is the Siemens. We've been evaluating both, and that's what we've learned.
The only system and I have seen that is cheaper than the Siemens uses a rope instead of radar. I saw it used in plastic filled silos with no real issues.
Basically it unwinds a rope and when the rope goes slack (weight has landed on the material it detects how much rope has played out and converts that into a level indication.
It is not real time feed back but for a every 4 hour reading it worked really well.
I have seen them used in grain silos as well but the silos where around 50' high. Below is the web sight for more info.
http://www.monitortech.com/product_c_c_sp.shtml
Ok time for the stupid question of the day. Aside from the fact that I can't figure out how to install it without taking all the grain out of the silo, why couldn't you put a pressure sensor such as a load cell in the bottom of the silo?
I don't think grain when it's sitting still behaves enough like a liquid for a pressure sensor to work.
I think current radar systems will do it very well.
I've worked with the Yo-Yo level detectors, and while they have been around a long time, they can be a real maintenance hassle. It probably depends on the product being measured.
But if we're talking alternative methods, bolt on load cells have been used for this application. Kistler-Morse makes some that do pretty well.
Because they paid me to...sorry couldn't resist... The compnay I work for we do it alot... The reason is batching... if your pumping the grain into a blender and you want to pump more than one material into the blender at a time the Loss In Weight you would have on the silo would tell you what you have discharged out of the silo and into your blender...
Note: on silo's you generally use more than one load cell because in most cases your supporting the entire silo on the load cells. Depending on who you ask a 3 load cell array works better than 4 but if you do the math that is pretty much "bunk"
FYI... it is not really a silly question, first time I did one I was thinking the whole time "There has to be a better way to do this"
Hello In my factory we use ultrasonic level sensor VEGASM61 to measure solar fuel in a tank. I contact with many suppliers to buy one. many of...
2,347
Dear, Consultant wants to use a bubbler system for storm water pumping stations, pumping stations is 800 liter/Sec. What is the benefit of...
4,549
Working on an industrial wastewater treatment plant... Do any of you have experiences with these? I'm changing our input signal from a...
18
7,001
Is there software out there that can connect to just about any Ultrasonic level transmitter and display what that instrument "sees". I think...
2,534
Hello, I've recently installed a ultrasonic level transducer to control a VFD pumping out of a vat. The vat is "slug" filled by other pumps...
3,999
