ultrasonic
ungaro
May 2005
Lokeren
72
nothing to do with plc... can electrostatic energy give problems with analogue utrasonic distance sensors tat can be used for unwinding?
Improperly shielded cabling would be my guess and/or an inappropriately shielded sensor
Hang an o'scope on the ultrasonic sensors input both at the sensor output - should tell you what you need to know
That would be my course of action
Rod
ESD can take out the electronics in a sensor, yes. It can also introduce noise on the signal leads.
Other things that can affect ultrasonic distance units include temperature, humidity, ultrasonic noise from air leaks, and the incident angle of the sonic wavefront on a curved surface to name a few.
Another thing that caused problems with some of our older sensors is air leaks. The leaks apparently produced a frequency used by the old sensors we had.
Is it good idea to use ultrasonic clamp type of flowmeter for water dosing? I already using the flowmeter pulse output by setting to 10L per...
1,296
Looking at a sensor wired directly to a PLC analog input (DL450) and trying to identify a make and model. Sensor is working, but if I sign a...
3,772
Hello, In my new company there is a lot of Sonobond welders model MH2026 with CLF2500 controller. Does anybody have any experience with this...
1,728
Dear, I am wondering if there is an ultrasonic type flowmeter (clamp on) for measuring flow in partially filled pipes. The ones that I was...
3,051
Hello all, This is an indirect PLC question. When detecting distance to the wheels (laid flat, rims up), ultrasonic sometimes gives erroneous...
20
11,056
