Unable to convert HEX word to bits *Modicon Quantum*
Ilya
Dec 2003
Hi!
I've got a problem.
There is a direct link method of communication between 2 Quantum PLCs.
PLC1 HEX word to PLC2 - OK, i.e. converting from word to bits in PLC2 is do right.
PLC2 HEX word to PLC1 - NOT OK,i.e. converting from word to bits in PLC1 is do wrong. Let me explain. There is a HEX word (for example 16#0002) on the input of the *WORD TO BIT* block, but there are NO active outputs of the block.
The configuration of *peer cop* of the both PLCs is equal.
Would you please tell me how can I solve this problem.
Thanks in advance.
Ilya Ragazinsky.
It is very hard to guess without actual program. What exact instruction used?
Try to copy source word to empty 4xxxxx and do it again,
Try to use a different destination.
Most likely your destiation or source overwritten by some data over instruction you can't see: some instructions used more than one register and search can't find this. What software used?
Check your PM
Alex
Thank you for reply, Contr_Conn.
I was trying to copy source word to empty 4xxxxx, also I was trying to use a different destination, but it doesn't work.
Please, check the attached screensavers.
What is PM I have to check?
PLC - CPU 534-14
Software - Concept 2.5 XL SR2
Ilya
In your example, the input to the WORD_TO_BIT command is a literal value (of 2 Hex) not a writable memory word, so the only output will be BIT 1.
If your first PLC is transmitting a HEX value into a memory word (such as 4xxx2) in the second PLC, no conversion is necessary to decode the bit pattern.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
273
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
142
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
135
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
89
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
150
