Unable to download program
technojuggler
May 2015
home
Hi all,
I am ready with a small program to be downloaded onto a ML1100 PLC. I have set up RSLinx and using the RSLogix Micro Starter Lite edition to download the program. I have followed all necessary steps to download the prog yet unable to download it.
The error says " Configuring the setting directly to a LInx Gateway is not allowed. Add a new TCP driver ("Remote Devices via Linx Gateway") in RSLinx Classic, and then select you path through this driver. "
Any thoughts of what I am doing wrong?
My PLC is communicating on Ethernet/IP protocol which I confirmed by capturing some packets to and from the PLC with wireshark.
You need to configure a path and driver in RSLinx... are you using a PM02 cable or only Ethernet?
If you are using a PM02 cable see here http://www.youtube.com/watch?v=QIu1AGUR4N8
If you are using only Ethernet you will need to use BootP (or others) and have to setup your Ethernet port on the PLC, that match the PC settings... once you have done this then make a program in RSLogix and make sure you have the same settings in the configuration section of the tree on the left
Once you are ready to download the program click on COMMS then System Comms then as stated in the video
Hello i have already created an HMI program for the TP1500, and i want to download the program to the panel and it seems to be no connection at...
2,101
I've a problem with program downloading in CX programmer. When I begin to download the program I get the message "Unable to download program(s)...
18
11,449
Hello everyone, I currently have a problem on one of our machines. I cannot download the S5 program. I only can upload it. Only DBs are downloaded.
5,466
Hello everyone, After a Deploy of the viewapp on Intouch, I started getting an error not allowing me to start the viewer "NAD unable to download...
948
Hi Everyone, I'm unable to download the project to the PLC. I have put the servos to the project and tried to download. Both verifying...
2,259
