Unable to download projekt to the PLC unit
TheGong
Sep 2022
Tampere
Hi Everyone,
I'm unable to download the project to the PLC.
I have put the servos to the project and tried to download.
Both verifying the controller and build goes fine with zero errors. but when I download the project it verifies everything and starts downloading. But when downloading Control TAGS it stops and cancels the download. And gives the following error:
Downloading all Controller Tags...
Error: $72a7e12a$: Couldn't be found.
Error: Failed to download tags.
Cancelling download...
Complete - 2 error(s), 125 warning(s)
Have anybody had this kind of problems
HI,
Yes sorry I forgot that from the msg.
PLC = Allen-Bradley 1756-L83ES, And the servo Drives aer 2094-EN02D-M01-S0
I found a couple of Tech Notes that discuss similar issues but not exactly. They suggest exporting the project to .L5K and re-importing it into a blank project to generate a new .ACD file, then downloading it. Have you tried that?
also check for tasks/routines that have declared tags but no code associated with them. so possibly there are still tags in a task but the routine it was associated with is gone now.
Being that this is a solution to a number of problems, I wish they would meet us half way on this and just added it to the menu. "We're not actually going to fix the problems, but we gave you File > Enema as a workaround" -Rockwell.
Hello everyone, After a Deploy of the viewapp on Intouch, I started getting an error not allowing me to start the viewer "NAD unable to download...
947
I was onsite yesterday and had issues going online with a processor. I could see the PLC in Linx, I could go to the webpage in a browser, but in...
1,781
Hey guy.... We had a machine built and the integrator used a version higher than 32.02 when they programmed it. I have 32.02 installed on my...
4,612
Hi, I am a new user of this forum and normally I use Siemens CPU, but in this case I am using a Allen-Bradley CPU and I need of help to update its...
1,275
Got a new PanelView Plus 7 Standard 600 and trying to transfer the app to it. It's telling me that it is not a valid terminal. I tried loading...
2,954
