Studio 5000 v33 unable to download
Sean Teague
Apr 2020
Tennessee
69
Hey guy....
We had a machine built and the integrator used a version higher than 32.02 when they programmed it.
I have 32.02 installed on my laptop and when i open the program, it says it was created with a higher version.
So when I go to download 32.04 or 33.01, it wont let me select it.
Do you have to buy a new serial # for anything above 32?
You have to have a TechConnect contract. The lowest level (Self Assist) allows you to download all the new software versions.
Hey guy....
No, you just didn't pay ransom when you got V32, as in support contract.
I don't do much, but paid for V32 for just two projects. It won't let me upgrade to V32.04 unless I buy it again.
Well, it was only about $932 the 1st time around. Tech Connect was another $1,270 on top of that, So cheaper to buy it again.
They were supposed to have the subscriptions out before that, but as usual, Rockwell is always late.
I believe most newer RA product download require verification based on Serial # before allowing download. You should not have any issues for accessing software versions if your license type is "Concurrent" with life term of "Permanent". Other license type I am not sure of and you should probably reach out to your RA rep.
That's what I thought, but mine is both "concurrent" and "permanent". It limits me to highest product version of 32.02.00, that's it. Wouldn't let me select and download 32.04.
Might just have to give Rockwell a call. Yeah, more frikin wasted time...
I have a serial and Product Key, but it wont let me select v33
You have to have an active support contract to access any version released after your initial purchase. I just went through this exact issue back in April.
My current situation is a follows: I have two similar 1769 controllers with similar programs. Both have a UDT array that is being used to store...
239
Hello Experts, I'm wondering if this has been done before if possible to create an Emulate file that have motion control axis? I tried to...
151
Hi everyone: I need to upgrade my Studio 5000 to from V31 to V33, but when I try to download from Rockwell PCDC, I only have the option up to 31...
1,405
Hello everyone, So I have an AOI that historizes data for the last 30 days, months and years. It worked fine for about a month, then I realized...
1,372
Hello, I am having issues updating a studio 5000 file to V33. Its currently on V32. When I go into Properties>Change Controller>Software revision...
1,049
