Unable to edit Factory Talk View ME application
FinlaySGS
Mar 2012
Scotland
When I open a ME application in Factory Talk View Studio 7 (CPR9 SR6) I can view everything as expected in the explorer window but when I double click or right click on any item nothing happens! So I cant view any displays etc.
I can use the test application feature and that works fine, I just can edit the application.
I have tried the usual uninstall/reboot etc, any suggestions?
Is it possible you have used 2 monitors on the project in the past?
I have had instances before when I have been using my laptop with an additional monitor, and the displays have been trying to open on the other monitor, even though its not connected.
Cheers
Mark
Also check to make sure all the objects weren't incorporated into the wallpaper.
Open the display and click "Edit" on the top drop down menus, go to the "Wallpaper" selection and see if "Unlock All Wallpaper" is greyed out. If it isn't greyed out, meaning you can select it, try clicking it and see if it unlocks the objects on the display.
You will have to do that for each display individually if that is the issue.
Thanks guys, I tried those with no success then accepted defeat shortly after.
I reinstalled FTView on a VM and worked first time. There is something installed on my workstation that the automated uninstall process (removing each individual FactoryTalk program through control panel/add-remove programs) doesn't clean up properly.
Hello, I have been trying to figure out how to edit data type for an AOI in Studio 5000. I keep getting an error "unable to modify data type...
538
I am unable to start any online edits, attempting to double click does not work and attempting to right click and select edit rung, but edit run...
12,722
I have a CLX L43 Rev. 15.7 processor that I installed about 6 years ago, the system includes a pair of ENBT's. One of which is dedicated to...
17
4,013
We got a new computer, and software a few mothes ago and have had plenty o' trouble with them. I know I should be able to edit online with...
23
52,329
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
239
