Unable to get the LOOKUP property of the WorkSheetFunction class
Tango7
Nov 2008
Gainesville, GA
This is my second post, and this time I come with a question. When I run the macro attached below, the first LOOKUP function will work fine, if the second one is not in the program. However, when I add the second one, I get the error Unable to get the LOOKUP property of the WorkSheetFunction class.
I am a VBA novice, and I appreciate any help that I can get.
Thanks.
Sub Auto()
Indexer = 0
Iterate = 1
Row = 3
RSIchan = DDEInitiate("RSLINX", "O2X1")
Do While Iterate < 2001
TempCarrierLot = DDERequest(RSIchan, "gCarrier" & "[" & Indexer & "]" & ".LotId")
TempCarrierStatus = DDERequest(RSIchan, "gCarrier" & "[" & Indexer & "]" & ".Status")
TempCarrierNextSta = DDERequest(RSIchan, "gCarrier" & "[" & Indexer & "]" & ".NextStation")
Cells(100, 1).Value = TempCarrierStatus
Cells(100, 2).Value = TempCarrierNextSta
Stat = Sheet1.Application.WorksheetFunction.Lookup(Cells(100, 1).Value, Range("AA2:AA6"), Range("AB2:AB6"))
NextSta = Sheet1.Application.WorksheetFunction.Lookup(Cells(100, 2).Value, Range("AE2:AE31"), Range("AF2:AF31"))
Cells(Row, 1).Value = Indexer + 410000
Cells(Row, 2).Value = TempCarrierLot
Cells(Row, 3).Value = Stat
Cells(Row, 4).Value = NextSta
Row = Row + 1
Indexer = Indexer + 1
Iterate = Iterate + 1
If Row > 49 Then
ActiveWindow.SmallScroll Down:=1
End If
Loop
End Sub
Found the answer
For some reason VBA didn't like the reference to the Cells(100,2).value that I used in the second lookup. When I changed that to the Variant the lookup worked perfectly.
Variants data types and boolean operations still don't seem to work right, which is why I tend to use the Cells(x,y).Value syntax.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
245
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
126
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
120
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
140
