Unable to Update RSLinx
Martin T.
Aug 2002
Northeastern Oklahoma
177
I have been trying to update my RSLinx from 2.43.10.23(CPR 6) for the last three days. Got a new ML1100 in and can't use it:mad: . Was on the phone with Rockwell for at least two hours to no avail.
I have a 2.50 RSLinx lite disk but every time I go to install it it comes up 2.43 is installing. I have tried to remove RSLinx but in the control panel it doesn't give me the option to REMOVE, I only have Change showing.
I have tried everything I can think of and am at my wits end. Has anyone had this problem? What's the fix? I've even booted up in safe mode but still don't have the Remove button.
Thanks:beerchug:
did you try to remove from the registry?
there are common files linked to RSlinks you have to delete them all before you install the new one.since you are trying to use micrologix there is hotfix to RSlinx 2.5 (i tried to attach the zip file but there is some problem in attaching) check the rockwell KB for the following documentation
"Catalog Number:
DocFullNum: R143736143
Revision:2.50.00.20 (CPR 7)
Fixed in Revision:
Package:
Module:
Is RSLinx running as a service, if so stop it
Go to Rockwell software/Rslinx/Launch Control
Run 2.50 setup - it will say 2.43, select "uninstall" or "remove" - I don't remember
After uninstall finished, reboot, start 2.50 install again - it will do it.
The reason that you see 2.43 instead of 2.50 first time is because it is trying to uninstall 2.43 first.
Thanks that was it.
Man I am feeling really stupid right now, that kept coming up and all I was selecting was modify or repair,o_O
Just goes to prove the older I get the dummier I am becoming.
same issue
i am having something very similar here. I attached the snapshots of the popup messages i got...is any familiar with this??? Please help
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
273
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
142
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
135
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
89
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
150
