Unable to Upload RSlogix5000
What are the Run, OK, and I/O indicators doing? What is your online status? What position is your key switch in?
I think the BAT indicator being grey means there is no trouble there.
The program can be Uploaded in any key position this is what the documentation say however I tried in all three positions and the same thing happen
Run goes to green if turned to Run Mode
I/O indicator goes green then goes grey I have attached a video
When I try to go online it does its thing and then fails to go to the online state
Your path looks correct, and I can see the processor connecting successfully. It looks like the connection to the processor is being terminated before the Upload Project dialog box opens up. Have you tried creating a new project in V15 using the same processor, and then uploading from that processor?
I tried connecting on channel 0 and DF1 driver
and no success , on windows 7 ethernet IP driver does not start
so used a pc with XP and able to upload succesfully when connected to the switch
do not understand why the ethernet/IP driver in RSlinx software
will not start when added as a new driver because this is what prevented from accesing program on Windows 7 pc
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,030
I have a machine that was powered off for repairs, when powered back on the Panelview fails to upload the tag database from the PLC. Its a...
1,542
I was onsite yesterday and had issues going online with a processor. I could see the PLC in Linx, I could go to the webpage in a browser, but in...
1,782
Hello all, I am trying to save a program from a HMI (GP577R-SC11) to QuickDesigner 3.70 and I get an error message at the VERY end saying it's...
4,719
I have successfully established communication using RSLinx class lite and RSLogix starter Micro lite but i am unable to download upload any...
3,044
