Understaning difference in programs
Prayder
Jun 2014
Arkansas
254
I am converting a rslogix 500 program into a Studio 5000 program but some of the instructions are not the same. For instance in rslogix 500 I have source that is RTC:0.HR and I am not sure how to convert that since I cant find an RTC instruction in the STudio 5000. Could someone please help me?
RTC:0.HR
I believe this is not an instruction but an address. Note the colon ( : ) and dot (.) delimiters. It looks like a Real Time Clock address
Sorry I dont know how to do ladder logic on here but your right... it is actually a GEQ instruction with source (A) showing RTC:0.HR <10 and/or source (B) showing 5
and then the rest of the rung goes on.
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
748
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
700
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,420
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,630
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,051
