Unity 8 Compatibility error when opening .stu files
cyclops
Jul 2010
Perth
I have multiple PCs with Unity Pro XL 8 installed. I am getting an error on one PC when I open an stu file that was created on another PC.
It says
"Project file not compatible:
Please open archive file (STA) to ensure the compatibility or import file (ZEF, XEF).
Remark: the import will need a full rebuild."
Does anybody know how I can ensure that I don't have this issue when opening STU files on multiple PCs? STAs take a long time to open.
I don't really know what the criteria for this compatibility is. The machines have been installed by the same installation files...
Thanks!
I would probably reinstall Unity on the pc that is coming up with the compatibility error
PS it is a good idea to save an .sta file in addition to the .stu file then if you need to open a program with a different version you can
As part of a comprehensive site survey, I have to mobilise to a remote site (offshore). I have also been asked to take a backup of their PLCs, so...
2,271
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
184
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
407
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
729
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,447
