Unity Pro and PID_INT
gripster
Dec 2010
Londinium
40
Hi all
Can someone lend me a hand with the PID_INT block in Unity Pro?
I have used the AB equivalent and it was self explanatory. I am struggling to see which of the I/O to the block is which? even in the ST it seems unclear, from the help file:
Representation in ST
PID_INT(Input_Tag, Input_Unit, Input_PV, In_Out_Auto, In_Out_Para, PID_Out);So where does it pick the Setpoint from and what is the In_Out_Para Array for?
Sorry if this is really straight forward and I have missed something. OR should I be using the PIDFF instance?
TIA
Have you looked at the help file in Unity
There is a full description of the function block io and how this block works
I followed the manual and created PID_INT block. Use the MOVE function to assign parameters such as SP, P&I, Max and Min output etc. Nothing changes in PID output. Any other setting I have to do?
Hi all, I have a request from client as follows, There's one PID for Control valve which would be controlling on basis of temperature. One...
1,526
Hi Out There, I am a control panel builder who has to contend with programming customers choice of plc. For the first time I have been lumbered...
5,091
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
184
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
407
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
728
