I have two quantum modicon PLC's over ethernet with an NOE card, i wish to read one REAL value from one PLC into another that's it really. I have read the schnedeir manual but doesnt help too much, firstly i need IO scanning setup on both PLC's?
Can anyone give me a good run down (start to finish) how to do this using IO scanning having problems (data types, setup in both PLCS) as can't get it to work, they are both on same network with unique IP addresses.
Also when i enable global data, i can not build the project comes up with a blue tick!?
I also note someone quoting "in stb the digital input address is 45392. Inorder to read this address in plc we write 45392-40001=5391 so we write in "Read Slave Index" column 5391 - i dont undestand this logic/nor what it means? but i see Slave index colum in IO scanner.
