Unity Pro with Momentum IO Problem
b104
May 2017
nova scotia
Hello,
I have a Schneider Electric Momentum 170 ADM 35010 base with a 170ENT11002 Communication Adapter and am trying to connect to it with Unity Pro but I cannot figure out how to get any kind of IP address from it.
I have the user guide and was able to calculate the default IP address from the Mac Address I think. I went from 00:00:54:25: D1:81 to 84.37.209.129. Correct me if I am wrong. But when i try to ping it or find it on a network scanner it isn't there.
Is there a way around this or is there any other way that I can configure this communication adapter?
Thanks.
You can automatically assign an IP using a DHCP server. If you're using an NOE or NOC card these have address servers. For the momentum adapter you use MAC address to assign an IP according to the manual. I haven't used these myself except on MB+ but I think they work similar to STB I/O
Alternatively you can set a fixed IP by accessing the http config page of the device using the default address you calculated. You will need to set your laptop to have an address on the same subnet, i.e. 84.37.209.50 or something like that.
I'm trying to find "IEC_BMDI_M" to use in my converted Unity Pro program to replace the old Concept "IEC_BMDI" but I can't find it in the...
2,402
Environment cpu 171 CBU 98090 170 AAI 140 00 170 ADI 350 00 170 ADO 350 00 Unity Pro V8.0 I use RSLogix 500 & 5000 all the time, have also used...
4,360
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
