Unity Pro XL - Problems w/ INTS and REALS math
FNC
May 2010
NJ
84
I need to do a calculation and am having problem.
INT1 := 2/3 * INT2 + 100
The real math is a bit more complicated but that is it essentially. Since 2/3 * INT2 is not an integer the software ignores it and says INT1 is 100.
I guess I'd like to assign it to a real then round up and assign it to an integer. Is this feasible?
Unity does not like any math involving integers and reals.
Unity enforces strict type casting, that is you can't mix types in mathematical operations. It does however have every type conversion function built in. Use Int_to_Real or Real_To_Int where required
Int1 = Real_To_Int( 2/3 * Int_To_Real(Int2) + 100.0)
Deal all, I am trying to configure the NOC 780000 via Unity Pro XL. My scope is to communicate with a flow computer via modbus TCP/IP. In NOC...
1,703
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
189
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
410
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
736
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,948
