Unity Pro XL v10.0 Download?
willpoll
Nov 2011
Seattle
Does anyone know of a good, safe place to download SE Unity Pro XL v10.0?
I have an old laptop with a legal, fully-licensed version 10.0 for a single skid-mounted piece of equipment and I don't want to upgrade to Control Expert and deal with new licensing when it seems I could just transfer the license to a newer laptop if I could just find the original installation file.
My IT dept. has been demanding I return this laptop for a couple of years, and I really would love to accommodate them, but I need to be able to troubleshoot and program this machine in an emergency.
Sorry if this is frowned upon, but I've exhausted my google muscles.
Thanks, Will
You might need to reach out to SE tech support, since you have a license they are reasonably accommodating. V10 isn't that old.
What processor is in there that means you need XL? M580?
Thanks Saffa.
I have a single M1E PLC running a small test plant, used for simulations to ensure regulatory compliance, while my actual production plant is AB.
I'm not familiar enough with the CPU to want to attempt updating the software to a newer version. Basically I have one PLC and one laptop to configure and maintain it that must always work when needed.
I'll reach out to SE tech support and see what comes of it.
Thanks!
Will
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
198
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
417
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
750
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,973
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
788
