Unknown compiler error
3wheeler
Dec 2017
TN
I have the RSLogix micro-starter lite free software version for the AB micrologix 1000 and 1100. We have 30 or more 1000s at our site. I have successfully connected to several of them with my laptop but some of them I can't. I can establish comm with rslinx but when I try to go online with rslogix I get "unknown compiler error" Can someone help me? Thanks
Hi and Welcome to the Forum,
If you check out the Knowledge Base article #8711 it will give you some ideas.
You will need a Tech Connect contract to access this article.
Basically is says that you will need to get a good offline copy of the program. Set bit S:2/4 to a 0 and then download to the processor.
Something to do with that bit is causing your issue. There are other possible solutions but that one was marked as SLC and Micro 1000 only so I would do that first.
Thanks Bullzi for the reply. I'll try your suggestion when I get time. My manager is a machinist by trade and don't understand that you can't troubleshoot and repair modern machinery with a screwdriver and pliers. I've been trying to get him to get me RS logix 500 for several years but to no avail. That's why I'm working with the free version.( With my personal laptop!) I'm sure he won't go for purchasing a tech support contract. Thanks again!!!!
Not a problem, glad to help. I know the subscription is expensive but if you are going to be working on these units as a normal routine it is money well spent.
As I understand the rules of the Forum, Rockwell frowns on us posting Knowledge Base articles in full on this site but we can "Paraphrase" the article to give you the important info. Otherwise I would have just copy/paste the article and we would have been done. So come on back and post again in you need more help.
Hi all when i tried to upload program from micrologix 1400 series b Firmware rev 14 , at the end of upload i am getting unknown compiler error...
6,489
I'm sure this question has been posted a thousand times on here but for me it was even funnier when I got to ask Rockwell / AB directly. My...
168
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
685
We are in the process of installing a new DC drive to replace a 1373 series Speedpak drive. There are 8 leads coming out of the motor -- Two for...
848
Hello all, I have an issue where RSLinx classic can see a PLC just fine. But when I use FactoryTalk Linx Browser to browse to the same PLC it...
861
