Unknown output pin on micrologix 1200
jommunar
Apr 2012
Laguna
21
Hi to all!
Can i ask help on this one. i cant seem to analyze what this pin is for
many thanks to those who will reply!!!
I agree that the output grouping can be a little confusing on MicroLogix controllers.
This model of MicroLogix has a mix of Relay and DC solid-state outputs. Some of the Relays have individual "common" terminals and some have grouped "common" terminals.
V AC DC 0 -> Relay -> Output 0
V AC DC 1 -> Relay -> Output 1
V DC 2 -> Transistors -> Outputs 2,3,4,5,6,7,8,9
V AC DC 3 -> Relays -> Output 10, 11
V AC DC 4 -> Relays -> Output 12, 13, 14, 15
You apply +24V DC to "V DC 2" and 0 V DC to "COM 2", and all the DC outputs on the controller are switched by transistors using that 24V DC source voltage.
The Relays can be used with any source voltage, within the groups indicated.
another question. if i interchange and apply 0V DC to "V DC 2" and +24 V DC to "COM 2", i could connect the negative terminals of the loads on the plc pins right?
As Ken stated in his post, these are the transistor outputs. they are polarity sensitive - you must connect positive to VDC and 0V to COM.
Hi, I'm new to this PLC game. Using RsLogix 5000 I'm trying to write a addon instruction that will write the result string to a destination SINT...
7,248
I'm sure this question has been posted a thousand times on here but for me it was even funnier when I got to ask Rockwell / AB directly. My...
168
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
680
We are in the process of installing a new DC drive to replace a 1373 series Speedpak drive. There are 8 leads coming out of the motor -- Two for...
847
Hello all, I have an issue where RSLinx classic can see a PLC just fine. But when I use FactoryTalk Linx Browser to browse to the same PLC it...
861
