udtwmc Member U Join Date Sep 2005 Location nottingham Posts 48 Sep 20, 2005 #1 Hi, How can one unprotect password protected blocks? cheers wayne
Borte Member Join Date Feb 2004 Location Norway Posts 238 Sep 20, 2005 #2 Lots of treads on this, you'll find it if your searching. But I did it for you: http://www.plctalk.net/qanda/showthread.php?t=16993 Cheers Borte
PLucas Member Join Date Apr 2002 Location Gillingham Kent Posts 1,742 Sep 20, 2005 #3 Wayne Perhaps you should have specified what PLC you are using, Borte has guessed that you are using a Siemens S7 300/400. If you want a precise answer to your questions then please state as much information as possible, including what type of PLC in use. Paul
Borte Member Join Date Feb 2004 Location Norway Posts 238 Sep 20, 2005 #4 That's true, I just assumed it was a S7 PLC since thats the only threads I've seen regarding untprotecting a block. Cheers Borte
PLucas Member Join Date Apr 2002 Location Gillingham Kent Posts 1,742 Sep 20, 2005 #5 Borte said: I just assumed it was a S7 PLC Click to expand... You probably assumed correctly, Given the little information (read, non existant) that was given, I also made the same assumption as you. Paul
udtwmc Member OP U Join Date Sep 2005 Location nottingham Posts 48 Sep 26, 2005 #6 sorry guys, i was a bit lacking in the information dept. but guess what...you assumed correctly! thanks again wayne
