unsolicited messaging
ganutenator
May 2002
kansas
1,440
Back in the 1990's I used unsolicited message to exchange data.
Aka, instead of the HMI polling the plc for data, I sent the data from the plc when it changed.
Why is this not a thing?
Is this even still possible?
And I could change the tv channel in a bar w/ my palm pilot.
And all vcrs worked the same.
I think it depends on the HMI.
Some HMIs do offer IO Messaging. I was just reading up on the Cmore from Automation Direct and setting it up to receive IO data from a ControlLogix processor, instead of asking for it.
Personally I could see the value of both, but the way HMIs are used in my applications (and, I would cautiously say, many applications) the need for the PLC to be the one sending the data rather than the HMI just asking for it doesn't really exist.
As long as you had an infrared transmitter, knew the TV/VCR model and IR codes, you could. But not sure what that really has to do with HMI to PLC data transmission other than the very generic "data being sent".
We are currently setting up the polling RSLinx for PLC's memory in 1000 msec and need to configure the controller to send unsolicited messages to...
4,978
Using VB.NET and OPC on testbench system. Trying to switch from Polled to Unsolicited MSG'ing using ControlLogix v15 and RSLogix 2.52. Polled...
3,461
Hello, I am running RSLinx Classic OEM v2.53 on a Windows Server 2003 R2 Service Pack 2 PC. I have two CompactLogix PLCs programmed to send CIP...
3,453
Hello, I am new to plc and am trying to interface with a compactlogix 1769-L35E through ethernet which is sending unsolicited messages every two...
4,361
Do me a favor, please! My problem: I use AB logix5562 with 1756ENBT in slot 1 to send unsolicited message with MSG instruction to OPC client...
3,636
