Unusual Switch / sensor needed Very Small.
milmat1
Aug 2005
North Carolina
209
I need to detect the motion of a netting material as it moves by a small window.
The material is a monofilament netting with 3/4" squares. I can use a very tint whisker / wobble stick type of switch if I could find one.
An optical sensor of any type might be hard to use. It would need a small sensing window(length) because of other parts below the netting.
Anyone know of a manufacturer of very small limit / whisker / wobble switches..?
I could let the whisker stick down into the squares, it would "Bump" as the material went past. It would have to have a very low tension...
Any Ideas???
How about a small adjustable capacitive type proximity sensor.
http://www.automationdirect.com/static/specs/prox12mmcapcm.pdf
You can mount the sensor against the glass window and adjust the sensitivity to tune out the glass. Anything touching the glass should then trigger the sensor.
Note: This would have to be experimented with to ensure it would work in your application.
Just a thought,
Regards,
I used the term window, but it isn't an actual window. I just have a small "Area" to look through...Sorry !!
The proximity capacitive sensor may still work for your application. If you use a shielded type that is threaded to the end.
You would have to test to pick up the netting material.
Agreed, I see some that are 6 - 30 mm and adjustable with both foreground and background suppression...IF they will detect the small surface area of the netting ?
You said you can drop a whisker type switch down into the netting? Could you put a reflector on the other side and use a retroreflective photoeye? There are also other style beam sensors that would detect the breaks in the beam as the webbing passed. Should be fairly inexpensive too.
What if you have the movement of the netting force the rotation of a roller , and sense the movement of the roller . Just a thought.
I installed some Rockwell Autom. apps using the files with the MD5 checksums below. Can anyone please confirm that these are the correct files...
2,559
Good Morning , We have a IMI Buschjost 24 vdc solenoid valve coil that is very hot . About 192 degrees . It stays energized for very long...
2,390
I think this may be a bit unusual, and I'm not even sure this is realistic or if this is the correct place to ask this question. Please bear with...
2,367
Hello, PLCTalk Community, I hope you can help give me a little perspective. I'm doing an in-depth failure mode analysis on a system that uses a...
8,179
Today, Orbital ATK fired the latest of their five-segment solid rocket boosters (SRB's), at the test facility in Promontory, UTAH. The center of...
1,698
