Updating IP Gateway of ENBT card in a Redundant Configuration
QasimFSH
Apr 2018
Adelaide
142
Hi All,
Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration?
So essentially what we have are two Chassis (one is primary and other is secondary). each chassis has one PLC CPU, two ENBTs and a RM module, and both the RMs (secondary and primary) are connected via fiber.
I want to update the gateway on all 4 ENBTs, but I of course cannot do it just by simply using RSLinx. The way I have figured out so far is to disqualify the syncing, update the Gateway IPs, and the requalify.
Is there any simpler/better way of doing this, please? Also, please note that we cannot afford stopping the PLCs or a full download; so only online changes are the option.
Thanks all!
As far as I know, there is no way to change it without disqualifying the system.
This setting will not cross-load. It needs to be set the same in both EN2Ts.
When you disqualify the redundancy, the primary is still in control, so you will not have a down time.
I usually set qualification to Never, then just pull the secondary module out and use a separate chassis to make a change.
Then change Primary module while running and then insert secondary and set qualification to Automatic.
You may also try System Update, but it also will disqualify the system.
139
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
117
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
117
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,027
Hello everyone, I am dealing with something annoying and excruciatingly basic that I am just ready to cry. I have updated some alarm messages in...
987
