Upgrade of proworks nxt program
buckian
May 2009
couva
Hi everyone!
I have a Telemechanique PLC whose program was written with ProWorks NxT. We want to upgrade the PLC because of the non-availability of hardware parts.
Can anyone suggest an easy way to upgrade the hware/sware to something with support and available spare parts?
thanks.
Well that depends on whats commonly aviable in your area- -because im based in north america i would default to Allen Bradly or Omron, but then it depends on what the memory structure of telemechanique is like - -i am not familar with those plcs so i cant say for sure - but you'd probably wana stick with something thats at least similar in memory structure.........?
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
174
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
281
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
295
