Upgrade to Comfort TP1200
Tweeker
Nov 2007
Smalltown
79
I am upgrading a MP277 10 inch panel to a TP1200. How do I keep the aspect ratio the same so my screens look correct? I am using TIA Portal V14.
In the settings, there are a variety of options controlling how the screens handle the aspect ratio.
Try a few different options, migrate it a couple times, and see which looks best as a starting point
MP277 10: 640 x 480 pixels.
TP1200: 1280 x 800 pixels.
Unfortunately the horizontal resolution is exactly 2:1 whereas the vertical is 5:3.
So if you choose to automatically fit the objects, there will be distortions. Circles will becomes ovals.
I think I would select a fixed ratio 150 % when converting the MP277 to the TP1200, and then manually adjust all the screen objects one by one (!).
edit: If you select the ratio 166% you should get the closest to fully filling the TP1200 vertically. Horisontally there will be some unused area. You can possibly move the screen objects around to make better use of the horisontal aksis.
Dont round up to 167% as some objects will be placed partially outside the viewing area, and thus will not be shown at all in the runtime.
But where do I change the ratio??? I've looked every where in Portal V14 and cannot find where to make the adjustment.
Thanks.
Here it is, and select the free scale factor.
And keep aspect ratio unless you want circles becomes ovals:
Thank you Jesper.
I changed the settings and downloaded to the HMI. The screens still look the same. In fact, nothing changes when I do a download. I tried to restore the HMI to factory defaults, but I cannot get that to work either.
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
55
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
176
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
282
