Upgrading redundant PLC 5 CPU to Controllogix. Need advise and highlights
flyers
Sep 2006
Amk
295
Hi guys,
We've a customer plant running about 10 sets of PLC 5 redundant, some of them has a few IO rack due to large quantity of IOs in the system. All PLC 5 are linked using DH+. These 10 machines are running independant. With the new budget approval they'd like to upgrade the PLC 5 CPU (mostly PLC5 40 and 60) to ControlLogix. While the IO will be still using PLC 5. We've not done any upgrade from PLC5 - CLX before.
Appreciate if anyone has done this can give me some advise what shall we check & clarify on the PLC 5 redundant system and shall we take good care?
We are thinking to propose to use redundant CLX running ControlNet + add an additional ControlNet module at the PLC-5 IO rack.
The PLC-5 ladder program should be rewrite manually in CLX style, right?
Thank you.
You should definitely get the local Rockwell sales team to specify the hardware configuration for you. They should be very happy to help you out and buy lunch as well. Redundancy configurations require specific firmware versions.
Ideally, yes. The conversion utility won't take advantage of the tag naming capabilities or other enhancements.
I have never built one from the ground up myself, but the ONLY way to do it is with ControlNet. That is a requirement of Controllogix redundancy.
I am not sure about using PLC5 IO. That would be the main issue. The best way to use PLC5 IO with ControlLogix is with ControlNet by far. However I am not sure if you can use the PLC5 hardware in redundancy at all.
It would be wise to contact Rockwell as stated above. You need to find out for sure about being able to use that IO in a CLX redundant system.
Once you know the answer to that, ControlLogix redundancy is very easy to configure. I attached the links to some manuals below. They will likely answer most if not all your questions.
RSL
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1756-um523_-en-p.pdf
http://literature.rockwellautomation.com/idc/groups/literature/documents/rn/1756-rn628_-en-e.pdf
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
458
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
567
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
901
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,145
Hello everyone, My company has an old line for building DC motors. Many machines are from the early 90's and some requests for safety...
1,169
