Upload omron c20k
indra
Apr 2005
indonesia
161
I have old type CPU OMRON C20K ( see attachment ) and I have communication module C20-LK201-EV1.
Does any one knows HOW to make setteing the DISP SW on this LINK ? ( see attached )
I also nedd info, is it correct to upload the program PLC, this CPU 20K, should be use SSS software and can not use CX PROGRAMMER ?
I also have the PRO-27 CONSOLE.
What I have to prepare for using this console, I want to monitor one by one the ladder but I can not find the port connector for connecting between PRO-27 and CPU C20K.
indra
the problem I do not have SSS ( under windows 98 ) only CX Prog but CX can not working for C20K.
I have to use console PRO 27.
Please inform me the adapter that I have to prepare for connecting between PRO27 & CPU C20K
CX programmer does not support the early small C series PLCS. However you can use SYSWIN software which was the forerunner to CX programmer and runs on Windows 95,98,2000 and XP. The LK201 HOST LINK communications addaptor you specify is the correct one for the C20 PLC. The DIP switch settings on the back of the unit should be as follows:
SW1 : 0 0 0 0 0 0 0 1 - This sets the machine number (Pins 1-5: always set to 0 for defualt PC-PLC host link comms) , the parity (Pin 6: even for all OMRON default RS232 comms), data format (Pin 7: always ASCII for default OMRON hostink comms) and run mode (Pin 8: 1 - PLC remains in RUN mode if host link module in plugged in , 0 - PLC enters PROGRAM mode when module is plugged in and can only be set back into RUN mode by the software while plugged in).
SW2 1 0 1 0 0 0 0 0 - This sets the baud rate (in this case 9600 bps which is the factory set RS232 default host link comms baud rate for all OMRON PLCs, try this baud rate first).
SW3 1 0 0 0 0 0 0 0 - This switch is always set to this and has no particular function.
HI CT,
Is it possible to get SYSWIN for free ?
If yes, please inform me the download area for this software
indra
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
200
Hi everyone, i have multiple Omron hmi terminals in the plant and i need to upload each program. i have an ns8-tv01b-v2 terminal in the office...
701
Hi all, i have multiple Omron units at the plant and some have analog, rtd, thermocouple, ethernet cards, maybe other specialty cards, i'm just...
16
1,727
Dear I am trying to upload project file from NB7 via USB cable, after entering the default password upload process getting started after few...
738
We want to upload program the following PLC, and downloading to Our Spare. And also we want keep program in file . Could You give quotation for...
1,233
