urgent control logix L55 firmware problem
hanyrag
Jul 2009
cairo
20
i have redundant system of revision 13 of 1756-L55 , CNBR/D and SRM ; with two I/O racks
i try to add 2 more I/O racks but using CNBR module release E and when i try to add this module in the application; i didnt find this type of modules
i figured out that the revision 13 don't have this CNBR/E module and i must use revision 15 or later
please advise me is revision 15 is suitable and compatible with SRM module with F.W. 3.39 and CNBR/D module with F.W. 5.51.1
as i saw in the manuals 1756-RN620A-EN-E that the revision 15 doesnt supported in redundancy system
hi all i am just new to the PLC analog world and i need to do some analog programming using Omron PLC ..so i need to know some points to start...
3,212
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
238
Guys, please help me with this urgently. We have Logic 5575 installed in hot n standby setup. For some reason, the primary now cannot sync with...
382
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,671
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
627
