Urgent Help required for PV300
francevendee
May 2005
Wales
48
I am new to Panelview/Panelbuilder32.
I have opened up a project in a PV300 where on different screens the function keys are tagged to bits say B3/65 B3/66 etc to start/stop pumps etc in manual
In the SLC 500 program associated with this panelview I cannot find these as the bits as expected are say B3:5/0 etc
How do I relate these from the panelview to the PLC program?
Is B3/64 actually B3:4/2?
Right click in your ladder window and select properties. In the Address Display tab, click the circle next to /bit and you will see the addresses displayed as the Panelview is referencing them.
Yes, France,
It is only two different ways for looking at the same memory address.
Method 1: File Number/Bit Number starting from 0.
Method 2: File Number/16-bit Word Number/Bit in the Word.
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,846
I am new with FactoryTalk and I have to modify the HMI which had some work already be done. Currently I am facing a problem how i open a popup...
2,316
Guys, firstly thanks for reading my post. Hope i get a response. I have a .MWP file and i need to access it on an urgent basis...i dont have any...
2,620
hello, All LED's on Siemens PLC(CPU 315-2 PN/DP)are blinking continiously & program is not getting downloaded in PLC.i try to format MMC card but...
8,865
Hi all. Can someone help. I have Omron an AD081 analogue card and i need to display the voltage (0to 10) on an Omron nt31c. I have the data in...
2,593
