Urgent Help Required
mshoaib
Jul 2003
Pakistan
Dear Professionals
i am facing problem with SLC5/03 OS300 which have no option of Floating point but i need this Floating Point In Ladder & Rsview for Flow totalization. kindly advise accordingly.
regards
shoaib
Shoaib,
You will have to use integers to total the number of pulses received
and then divide this in RSview to get the total in floating point format.
e.g. 1 pulse = 0.1 litres
SLC Counts 235 pulses
RSview = 235*0.1= 23.5 litres
If the reason you need floating point is that your flow totalization generates a very large number, then there do two things you can do:
1. Upgrade your SLC5/03 to the latest firmware, it is not very expensive.
2. Write som ladder code that effectively provides you with double-word sized variables.
Hint: When var1 reaches 10000 and 1 is added to 1, the reset var1 and add 1 to var2.
I second looking into a firmware update. It is reasonably priced and you will make up a portion of it with the reduced programming time. The upgrade is really simple to do.
OS300, circa 1993
An OS300 operating system SLC-5/03 is probably a Series A unit, which is not upgradeable. I have a couple of those with OS300 and OS301 that are basically relics because they can't use the new features of OS302 and Series C (a.k.a OS310).
You'll probably have to use cascading integer accumulation registers.
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,842
I am new with FactoryTalk and I have to modify the HMI which had some work already be done. Currently I am facing a problem how i open a popup...
2,313
Guys, firstly thanks for reading my post. Hope i get a response. I have a .MWP file and i need to access it on an urgent basis...i dont have any...
2,619
hello, All LED's on Siemens PLC(CPU 315-2 PN/DP)are blinking continiously & program is not getting downloaded in PLC.i try to format MMC card but...
8,859
Hi all. Can someone help. I have Omron an AD081 analogue card and i need to display the voltage (0to 10) on an Omron nt31c. I have the data in...
2,590
