Usage (A,B) shaft encoder (X4)
HenryLamboo
Jul 2005
Achterhoek
87
Hello,
I have two questions about an incremental shaft encoder connected to a PLC. The encoder I use is an incremental shaft encoder with Channel A and Channel B and gives 125 pulses per rotation. I connected the encoder to an Unitronics PLC. For the configuration I can select a High speed counter, (A,B) Shaft encoder (X2) or (A,B) Shaft encoder (X4). I see 125, 250 or 500 pulses per rotation.
For me the (A,B) Shaft encoder (X4)is the best because this gives the most pulses.
Can I configure this encoder as an (A,B) Shaft encoder (X4)?
Can somebody explain me the difference between een X2 or X4 shaft encoder?
Henry
The A and B channels of the encoder, when being rotated at a constant rate, are two square waves offset by 90 electrical degrees.
Let's interpret the signal going from left to right as an increasing count.
"R" = Rising edge, "F" = Falling edge, "L" = Low, "H" = High
X1 = AR and BL = increase count, AF and BL = decrease count
So an increment will happen once per full cycle of the A clock
X2 = X1 plus AF and BH = increase count, AR and BH = decrease count
So an increment will happen twice per full cycle of the A clock
X4 = X2 plus BR and AH = increase count, BF and AH = decrease count
BF and AL = increase count, BR and AL = decrease count
Now we have an increment happening 4 times through 1 full cycle of the A clock.
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
179
Hi everyone I am using Winproladder software for programming FATEK FBs PLCs and in programming, we often use Timers for activation of the...
593
Anybody have any experience using a tone generator on analog signal wires? Trying to locate two analog level sensors in an old plc5 panel that...
998
Dear all, I have some query about the use of Timers in Fatek PLC Module by using WinproLadder Software. I am trying to use one timer instance in...
1,258
Hello, I was looking for some advice. Is there functionality within WinCC (V7.5) to report , list or export all tags that have been used within...
419
