RMA
Hallo Jesper,
I was hoping you'ld show up again. The idea with loading a new program via the prommer sounds like it ought to provide the solution to the problem. We'll find out tomorrow morning! thank goodness I got the prommer working again in the end!
I really ought to go over in detail what I really need to have in NetPro. Since this my first meeting with networked stuff, I'm sure I've got a load of (unecessary) rubbish in there. I suspect the only thing I need is the Ethernet link to the customer PC for the FTP data transfer.
@Fred: Thanks for the suggestions, but I'm caught in a situation with current project equipment - no way I'll get authorisation to buy anything new! It is a CP5611 I've got because I'm using the future HMI desktop also as the development PC. Hopefully Jesper's come up with the solution with the Prommer. If not, I'll be back in panic mode tomorrow morning!
Edit: Nearly forgot, on the top-end 300's which have a dual MPI/DP port, you can indeed drive the MPI at 12 Mb - electrically MPI and DP are the same.
