USB Ethernet adapter for Windows 7
jkerekes
Aug 2007
NJ
2,363
Who makes a USB Ethernet adapter that runs under Windows 7? I have a Netgear FA120 that worked fine under XP and now doesn't under Win 7. The Microsoft Compatibility site now says it should work under both 32 and 64 bit Windows 7 w/o driver software needed. I'm running 64 bit. I can't get it to work. I wuld like to buy another that definately works with Win 7. Any suggestions? Thanks!
Next week we will be coming out with our Industrial USB to Serial cable/adapter that will have the 64 and 32 bit drivers, we now have just about all drivers updated for our USB cables and they soon will all support Windows 7
Send me an email and I will send you one for free as I need to get feed back before I start selling them to everyone, just let me know what your details are on your system, brand of PC, version of Windows and what if any issues or success you had using our cable after you receive it...
Mark
[email protected]
Mark
[email protected]
Ethernet != Serial o_O
You know what? I wasn't reading this thread carefully either! I need a USB==>Ethernet adapter that works under Windows 7 64 bit. I need some recommendations.
Next week we will be coming out with our Industrial USB to Ethernet adapter
Better??
I did not know I had to spell it out... we should have both
But also like I said in the email that I sent, you should try that link that I sent, they have helped me before
I just wnated to make sure. I thought I understood your first email correctly. But after reading some of the other posts, I wasn't so sure. I'm sorry if my post was misunderstood, no insult was intended.
Better??
Didn't mean to confuse anyone, sorry if I did. I just noticed that the OP was asking for a USB to Ethernet adapter. I know you sell USB to Serial adapters (high quality too, by their reputation), and I assumed that the adapter you mentioned in your original post was an industrial-duty version. I also did not see any USB to Ethernet adapters listed on your website currently. From my vantage point, it looked like there may have been a disconnect in the OP's request and your offer, so I posted. šŸ™ƒ :)
Brian
Hi Brian,
No big... I should of made it more clear, I did spell it out better in the email that I sent but no one other then jkerekes would of seen that, sometimes you get caught up in these forums and think that you are having a conversation with one person....
I have two new adapters (I hope) coming out next week, I have nothing to do with the Ethernet side but I am told it looks like it will be ready, the USB to serial (DB9) is done.
Thanks for the complement
Mark
Hello, I am attempting to connect to a PLC and the peripherals via USB to ethernet adapter plugged into the unmanaged switch and having issues. I...
2,672
Hi I just given a swanky new laptop at work, which is lovely and everything, but does not have an ethernet port. Unfazed by this, I just got hold...
3,116
Anybody using a usb-over-network adapter to go online with PLCs remotely via PLC USB port or USB>XXXX converter? I've looked around at what's...
17,779
Hello, So, the laptop that i have to temporarily use has no lan port. Does anyone have a proven working usb to ethernet adapter brand? I have to...
2,077
Hi All, I have had a look through this website but can't seem to find what I am looking for. I have a virtual machine running Windows 7. My...
3,090
