dipakdevare
You can use branded serial to USB converter like from MOXA or CONTEC . You will comeout of all the problems happended due to low cost converters.
Dipak Devare
Dipak Devare
gilnutz said:Thanks for everybody's input on this, What brand and model of PCMIA to Serial adapter would be recommended?
Thank You Again
Billy
Ken Roach said:"RS232 Made Easy", that's Martin Seyer's classic; I have one right here by my desk too, next to my dusty copy of Machinery's Handbook 24th Edition.
Seyer's book is excellent when you want to do a reality check for yourself about pin assignments and DCE versus DTE definitions.
The Machinery's Handbook is a lot heavier, and I occasionally use it to smack people who insist that DH+ is RS422.
I am a big fan of the Keyspan HS19 USB/RS232 converter. It has never failed me, and even includes some nifty diagnostic utility tools.
ToolGuyFred said:I have used four different USB to serial converters, all successfully with A-B, Omron and Mitsubishi gear. So long as you go into device manager and view the hardware to see which port is assigned to the converter, things seem to work just fine.
Big John T said:I have the 1747-UIC for DH485 but most of the time I need DF1. If I change the user port to DH485 then no one else would be able to communicate with it... I can't even remember when I used DH485 last. Now that you brought up data highway I do need to have DH+ from time to time for SLC 5/04 processor and my laptop does not have the slot for the PCMK card, I have an "Express" slot that is useless. Is there any other way to connect to DH+ or a SLC5/04 processor besides a compaclogix backplane with a DH+ card and an ethernet card?
John
Russ said:It will cost you about $40. Pick up a keyspan usb to serial (Compusa sells them). I've used it to communicate via channel 0 to slc 5/03's, 5/04's, and plcs. It works great!
I had to pick up one of the uic modules because the two 5/03's I service don't have the 'pass through' option (ancient firmware), and I needed to add some missing alarms in the panelview. It was highly doubtful that either plant would be interested in upgrading firmware for a subcontractor lol (plus it'd cost a lot more than $250) .
It works great too! I just have to remember to set up linx as a service.
