USB to Serial converter
ade
Mar 2005
Bandung, West Java, Indonesia
46
Hi all,
I just Lost my Compaq Presario 2100 laptop and company provides me with Compaq Presario 2500. These Laptop was normally used for programming, troubleshooting and other PLC/PanelView related work which requires a serial communication port. Unfortunatelly, the Presario 2500 has no serial port. And I search the internet thru google.com and I found a USB to serial converter (http://www.usbgear.com/U232-P9.html).
My question is, is there anyone has an experience using these converter (or the other brand converter) to connect your laptop to serial-devices (SLC 5/04 for exapmle)?
Your commentsand suggestion would be greatly appreciated.
Thank you
Best regards
-ade-
Same problem, got a convertor and it worked fine not a hicup, Touch wood, that was just a bog standard run of the mill oneRoline unit DTR 230 Kbps. Although if you used the PIC unit (DH485) to talk to a panelview then as far as I know you will need a 1747-UIC. Again I have used it recentlly had can not report any problems.
Hope this helps.
Depending on how many different software packages you are working with, the usb converters may or may not work properly...... The best thing I've come up with is to pick up a "port replicator", which is a type of small docking station. This gives you a true serial port.... Do a search for usb and converter here in the site, and I believe there have been a couple of lists made up concerning which converters work with the different software packages
ATEN makes one that seems to work with everything I've ever thrown at it. I think the catch on the ATEN is that it is an honest serial port (not really a converter/adapter) that connects via USB instead of PCI to the CPU.
This is a topic, I have been wondering about for some time!
Thinking of byeing a new laptop, but as I,am working in a lesser payed job to gain experience! funds are small! most of my software i own is old and ms dos based.
So my two main concerns are that the software wont run on XP and most laptops only have usb ports now.
One option is to partition the drive and run an older os! and also get a usb convertor?
obvisouly if i had the money would just buy all the latest windows based software.
So does anyone have any useful advice on what to buy? also want to use the laptop for basicly everything i do as dont get back home to my desktop much !!!!!!!!!
All recomendations welcome.
I think you'd better find a laptop with a serial port. Several of the IBMs still have them and even some Dells. USB-RS232 converters, adapters, etc (including the ATEN I mentioned) only have Windows drivers; if you need to boot into dos you're probably going to be up a creek with out a built in serial port.
And some don't.... :(
BTW, Compaq (HP) has some laptops in its range with built in serial ports.
Not all, but if you specifically ask for a serial port, you will get it.
(I know it dosn't help you now, but maybe next time)
I have purchased a HP recently with a real serial port. It is really a re-badged Compaq. So happy I got away from the USB/serial converters and I had a good one that was sold by Omron and worked really well to any PLC I connected to. The problem was big footed electricians in plant rooms falling over your cables all the time eventually destroyed the USB ports on the laptop. I can screw the cable into the serial port. Not to say that the serial port will survive either.
The laptop was a HP XE3. The thing I really loved about the laptop was HP placed a button in front of the touch pad. You could turn the touchpad on and off. Really marvellous. No more typing rubbish in the middle of nowhere. I am sure most of you know what I mean. Unfortunately that wonderfull feature has yet to migrate to the Compaq laptops.
try the second hand market for a reasonably old used laptop. The company I work for bought me new one two years ago.Had to then buy two new sets of software to run in the Xp environment.
Until recently, I haven't had to connect to a piece of hardware using a serial connection in quite sometime. Well, that all changed yesterday when...
33
6,341
Dear experts, I can't connect to Siemens s7 200, I have Siemens ppi cable but I don't have serial port on my pc so I used serial to usb converter...
4,550
Hello Chaps I'm usually a BMS controls engineer however we get sent on call outs to fix PLC systems. I have a job where I need to connect to...
8,892
Hai All, I have a PLC(MItsubhishi Melsec FX 48 MR) With me, which is having Serial interface DB 25 port on it. If I use DB 25 to usb...
5,153
guys, am having a problem in my laptop, i can't communicate with AB or GEfnuc PLCS by using the USB to SERIAL CONVERTER.. the configuration of the...
2,482
