USB Virtual Com Port Driver
becs
Mar 2012
Ontario
20
I have a 1747-UIC from AB to connect to my SLC 500s in the plant. In RSLinx I need the computer to see the USB port as a Com port.
On the Rockwell site I found the drivers for this device. I initially loaded everything correctly, but the driver for USB->Com seemed to have unintalled itself. Trying to reinstall the driver I get a message telling me there was a problem installing this hardware.
So I am on the search for another driver so my computer will see the USB port as a Com port, but haven't had much luck searching through google. What are the chances that anyone here might be able to point me towards a driver I can use?
Thanks!
Try un-installing the UIC and re-installing it, I would also use the drivers from the AB site they work great with XP or Windows 7
I must confess that I haven't used the 1747-UIC. I have, however, used similar USB comm devices that required me to manually check Device Manager and then configure my software to work with the comm port number that was automatically (and arbitrarily) assigned to the device by Windows when the device was detected. Real, legacy comm ports had fixed comm port addresses and/or interrupts assigned to them, so this was never an issue after the initial software configuration was done.
Hello everyone, I have some problems regarding using the Schneider PLC USB driver within a virtual machine. I am currently using VMware...
2,111
I've got a CompactLogix plugged in by USB and the computer seems to see it. But when I try to add the Virtual Backplane USB driver in RSLinx...
8,175
Gents, I've a Laptop with W7 64 running, and MS Virtual PC for WindowsXP. On this WindowsXP I've installed Siemens Step 7 V5.4, and like to...
13,679
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
177
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
129
